Named Selection working order matters
I have created a named selection with a surface, lines and control points of 3 different curves as shown in below picture.
When I select the saved selection via the panel, only the points are highlighted as shown in below picture. The command bar mentions something else:
3 curves added to selection.
1 surface added to selection.
When I use move, only the control points are moved.
I tried another order:
First start with the command Move
Then select the named selection.
The named collection seems to be selected correctly, but only the control points are not moved.
McNeel, can you add this to the bugs-to-be-changed-list? :wink:
My Rhino file:
ProblemNamedSelection.3dm (77.4 KB)
Cheers,
Bas
Rhino 7 SR8 2021-7-15 (Rhino 7, 7.8.21196.05001, Git hash:master @ 45c1fd6dc85c7c1cce8c0bbe6f3e16481ae9abfa)
License type: Commercial, build 2021-07-15
License details: Cloud Zoo
Windows 10.0.19044 SR0.0 or greater (Physical RAM: 16Gb)
By the way: the help about named selections is not complete:
https://docs.mcneel.com/rhino/7/help/en-us/index.htm#commands/namedselections.htm?Highlight=named%20selection
Missing is: Click what???
Hi Bas - so far this works as expected here, in your file.
"Rhino 7 SR8 2021-7-15 "
You might try installing a newer service release of Rhino 7 to ensure you have the latest bug fixes and see if the problem still exists.
Thanks, it seems my IT department has disabled the update function. Sorry for that I did not notice this.
