Dear Rhino Users and Developers,
how can I add name to recently created object. I have string of its path, which I would like to put as its name.
obj=scriptcontext.doc.Objects.AddPointCloud(…)
Thank you for any help.
Hi @mlukasz87,
You can do that using the ObjectAttributes Class
# myPointCloud is a pointCloud defined elsewhere
# myName is a string of the name you want, defined elsewhere
import Rhino
import scriptcontext as sc
attributes = Rhino.DocObjects.ObjectAttributes()
attributes.Name = myName
sc.doc.Objects.AddPointCloud(myPointCloud, attributes)
sc.doc.Views.Redraw()
Hi @lando.schumpich ,
I didn’t mentioned that I am using Rhino 5. I have found that equivalent for Rhino 6 class ObjectAttributes could be RhinoObject, but Rhino is not allowing me to use:
attributes=Rhino.DocObjects.RhinoObject()
I get this message while debugging:
Cannot create instances of RhinoObject because it has no public constructors
I could instead try to use this after creation of point cloud
rhinoscriptsyntax.ObjectName(strID,myName)
but I don’t know how to get its ID?
Could you provide some advice how to succed?
Ok I have found that I missed the most obvious. In fact
obj=scriptcontext.doc.Objects.AddPointCloud(myPointCloud)
is storing ID.
This worked for me. Makes job done and I am ok with that. Anyway I appreciate your help @lando.schumpich.
rs.ObjectName(obj,myName)
scriptcontext.doc.Views.Redraw()
Dunno, this seems to work in Rhino 5:
import Rhino
pc=Rhino.Geometry.PointCloud()
for i in range(5):
for j in range(5):
for k in range(5):
pc.Add(Rhino.Geometry.Point3d(i,j,k))
attrs=Rhino.DocObjects.ObjectAttributes()
attrs.Name="MyPointCloud"
pc_id=sc.doc.Objects.AddPointCloud(pc,attrs)
Adds the point cloud to the document with the name attached…
