Give Object a Name with Rhino Common?
Hi all,
I tried to Add a Name to a Object but it is not appearing in the Rhino UI but if i print it the object attribute.name exist.
import Rhino as rh
L = rh.RhinoDoc.ActiveDoc.Objects.FindByLayer('Line')
for i in L:
    print i.Attributes.Name
    i.Attributes.Name = 'Test'
None
Test
A tip why the name dont appear in the object property panel is welcome
Unbenannt
Solution found
import Rhino as rh
for i in L:
    att = i.Attributes
    rh.RhinoDoc.ActiveDoc.Objects.ModifyAttributes(i.Id,att,True)
Unbenannt
rs.ObjectName(object, name)
If you are using python inside the rhino python script editor.
I try to avoid rhinoscriptsyntax but thanks for your solution
