Can RhinoCommon set Rhino object names?
Rhino objects have their names exposed via RhinoObject.Name, but this property is read-only. Is there a way to programmatically set the names of existing objects with RhinoCommon?
Seems like it could be done through scriptcontext.doc.Objects.ModifyAttributes:
import scriptcontext as sc
id = rs.GetObject("pick something")
rh_obj = rs.coercerhinoobject(id)
attrib = rh_obj.Attributes
sc.doc.Objects.ModifyAttributes(rh_obj, attrib, True)
rh_obj.Attributes.Name = "someName"
rh_obj.CommitChanges()
Check the object.py file
djordje,
I see that this is an old posting but I have a question for you. Once you give the object a name is there a simple way to select it on screen by it’s name?
Eric
@eric.bunn,
Rhino has a SelName command .
Does this help?
– Dale
Hi Eric,
You can call “SelName” command through rs.Command function, as Dale showed.
Or call rs.SelectObjects:
name = "Jelisaveta"  # name applied to one or more objects
id_L = rs.ObjectsByName( name )
rs.SelectObjects( id_L )
Thank you djordje.
Eric
