Help!! My Layer window some how separately from my window…and I double click the up corner of layer window become the strange layout? how to restore the normal position for the layer window?
Rhino’s windows are dockable. This means you can grab them at the top and move them around in the Rhino main window or even move them outside the Rhino window to become separate, independent windows. This seems to be what you’ve done.
Just grab it on the top and move it back within the Rhino window. As you move it around in the Rhino window you will see a color block appear which indicates a position where you can drop it and it will attach.
I suggest you bring up the Rhino help screen and look for topics on window, toolbar and display management. The help is a great tool to become familiar with.
thanks a lot. I use your suggestion and already locate the window to normal position.
