I want to loft these lines, so it will become one smooth surface. All the lines touch each other, so I don’t understand why I get these weird forms. Does anyone know what I’m doing wrong?
LOFT.3dm (893.7 KB)
LOFT.3dm (893.7 KB)
Hello - Loft
is for curves that are all in the same direction - more or less parallel. In this case your curves are in two directions including one, the outer edge, that has some of each - this is a hard to surface from these inputs directly…
something like this -
https://docs.mcneel.com/rhino/6/help/en-us/index.htm#commands/loft.htm?Highlight=Loft
Thanks!
I did it this way because I followed a tutorial on Youtube (https://youtu.be/z29OXdZjMLI?t=73, at 1:13) and that guy simply selected all the curves and clicked on loft. but when i tried this, it looked not the same haha
He started to use Loft and then switched to using NetworkSrf instead.
Thank you! Now I get it
