I am going to be laser cutting paper and I only need single line segments. However, Illustrator created complex arc forms. Are there any commands that can transform the multiple shapes into single lines?
convert
I tried the convert command, but nothing happened. The curves remain the same
Did you make sure that Output=Lines in the command line options? There are a number of options there. If so, it’s probably best to post the curves you’re talking about.
