Making one single curve without breaking
Hello ,
Could you please help me about my problem ?
I insert a dxf drawing to the rhino.It came like block.I explode it.But I have to make all lines and curves , one single line or one single curve.
Because I will send this drawing to the 3d printer but it has to be just one ine or one curve.
How can I solve ?
Normally, if the segments are all lined up correctly, the command Join should do what you want…
Hi -
Apart from what Mitch said, unless those curves make up the slices, it doesn’t make much sense to send curves to a 3D printer. It’s probably best if you upload (part of) your 3dm file.
