Multipipe Problems
Hi @jhunterf
I don’t have the same plugins installed, and the data isn’t internalised, so I can’t test your file, but one thing to be aware of with the GH version of multipipe is that it doesn’t automatically split curves at intersections. If you have curves that cross and want them to have a node there, you’ll need to split the input into segments that have end points at the crossing.
It could also be a tolerance issue, where there are small gaps between end points in the input, like here:
