MSweep as Meshpipe with variable Radius
Hello sparkling dazzling fizzy bubbly community :seedling:
Attempt of MeshPipe with variable radius from a list of rails.
First, I created circles oriented at the start/end of each rails.
Then tried to compile everything with MeshSweep.
I am clearly missing something with graft and flat. Any idea ?
This would be helpfull to get another way for understanding Trees beside this great document :
https://modelab.gitbooks.io/grasshopper-primer/content/1-foundations/1-5/3_creating-data-trees.html
Bonus Question : What component should I add to get roundish caps for the Mesh sweep ?
:sun_with_face:
MSweep var radius.gh (195.0 KB)
Hey Ghali,
Now I may be hideously wrong, but I don’t think MeshSweep allows for multiple sections (there is nothing wrong with your understanding of grafting and flattening here from what I can see) - you could do it as a NURBS Sweep and it gets your the results you need but the gaps may be a problem.
I feel like I might be becoming a bit of a broken record, but Cocoon deals with all of these issues for me
MSweep var radius.gh (185.0 KB)
Does this help?
-Sash
Hello Sash !
Thank you for your answer it’s beautifull! (This will give me opportunity to work with cocoon and graph domains).
I actually did a model with NURBS variable pipe but as you expected it is awefully long.
I tried your definition but I can’t get it to work. I have some error regarding plankton.
Downloaded the latest version of Plankton, and the 0.3 (and checked unblock component) but nothing changes. Maybe you have a hint on this ?
**Edit : I needed to also upload the Plankton.dll in the component file.
https://www.grasshopper3d.com/m/group?id=2985220%3AGroup%3A875392
