Oh great, scaling the bigger curve using a relocated gizmo essentially flips the result seemingly randomly… at least I can sort of sketch the surfaces without having to recreate everything between each iteration now… ![]()
Hi Robert -
Should I be doing something differently?
That flips it for me. Weird, so here’s my sysinfo:
Rhino 7 SR37 2024-4-16 (Rhino 7, 7.37.24107.15001, Git hash:master @ d2e42f70b9d3aa58f6053e2998a0db2abcd7555b)
License type: Commercial, build 2024-04-16
License details: LAN Zoo Network NodeWindows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 32Gb)
Computer platform: LAPTOP - Plugged in [99% battery remaining]
Primary display and OpenGL: NVIDIA Quadro RTX 3000 with Max-Q Design (NVidia) Memory: 6GB, Driver date: 4-11-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 552.22
- Windows Main Display is laptop’s integrated screen or built-in portSecondary graphics devices.
Intel(R) UHD Graphics (Intel) Memory: 1GB, Driver date: 5-31-2022 (M-D-Y).
- There are no monitors attached to this device. Laptop lid is probably closedOpenGL Settings
Safe mode: Off
Graphics level being used: OpenGL 4.6 (primary GPU’s maximum)Anti-alias mode: 4x
Mip Map Filtering: Linear
Anisotropic Filtering Mode: HighVendor Name: NVIDIA Corporation
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 4-11-2024
Driver Version: 31.0.15.5222
Z-Buffer depth: 24 bits
Total Video Memory: 6 GBRhino plugins that do not ship with Rhino
C:\Users\robert\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\NVIDIADenoiser\0.4.1\NVIDIADenoiser.Windows.rhp “NVIDIADenoiser.Windows” 0.4.1.0
C:\Users\robert\Desktop\BlockEditNew.rhp “BlockEdit” 1.0.0.0Rhino plugins that ship with Rhino
C:\Users\robert\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\PanelingTools\2021.3.2.446\PanelingTools.rhp “PanelingTools”
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.37.24107.15001
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.37.24107.15001
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.37.24107.15001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.37.24107.15001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.37.24107.15001
Your gif at the top looks to me like the whole surface moves, not the control point…
Hmm, OK, I can repeat it here. Odd. What command did you use to create the surface from those two curves? I tried with Sweep1 but it does not react the same way as the original surfaces in the file - it reacts like @wim’s test.
Ah, once again, if only there was a query edit in Rhino…
It is a Sweep 1 but it matters at which end and in which order you pick the curves.
You have to click the left side of the top curve first (that’s why I have a different colored backface in my display mode).
