I built a curve from 22 control points. I did a 2d scale and made length shorter and moved it up the y-axis of the ref plane. If I build a surface between the two curves (EdgeCurves) I get a good surface.
If I move the upper curve back on the x axis (same y location) and build a surface I get a surface the folds on itself. It appears the control points on the upper have reversed from the lower curve. Same curve and control points only moved out x axis 5.5 inches. I’ve tried to find a way to reverse the order of the control points but no luck. Any suggestions? Using 8.0 windows.
