So I have different polylines (contour lines) all at the same height (C Plane) and wanted to know if there is any way that I can move them in the Z Axis according to multipliers. So since my contour lines are every 0,5 meters it would be moving each line 0,5 more than the previous one.
without seeing your contour line, this is the best I can offer you
this assumes you only have one line per height, and that you’ve inputted the curves into GH in a specific order
if we’re talking about terrain CAD files, there’s probably form kind of text that indicates the height of the contour line, in which case you’ll need a plugin like Human to read that text and find the closest curve to it to associate the height
I’d like to follow up this discussion.
I have a set of 394 flattened contour lines and need to elevate them in a 0.6M interval, by which I can then use other scripts to create a terrain mesh.
Is there anyway to reduce the work load of manually select each curves?
thank you!
