Hello, I have a boat model which I want to calculate the sinkage using orca3D. The model does not move to the zero, zero,zero coordinates. Please find the attached. I try everything in this trail
V4.3dm (1.3 MB)
Hi Emmanuel -
You have custom CPlanes active in your viewports. To make sure that you use the world default Cplanes, run the 4View command twice in a row.
Does that help?
Also, you can type in ‘W0,0,0’ as the target for Move if that is how you are doing it.
‘W’ will force any following XYZ coordinates to ignore the active CPlanes and go to the World based location.
