Move in Z 4 branches
Hi! I need to move this grid in Z 4 or more times, and can’t seem to move them correctly. I believe there is a lists problem, how can I solve it without losing the tree structure?
move grid.gh (2.9 KB)
A grafted move will work, probably best practice to match the tree first though.
Oops, misunderstood the question.
Without graft or group, this would be what cross-reference is for.
Doesnt work :frowning: @Rickson
it should
Why did you use path mapper? And also why shift path? Sorry I’m new and I am trying to learn. Thank you very much!!!
Cross Reference version
YEs, but the tree structure is different now
How can I change it back?
Solved this with Tree Match
I used path mapper to flip the branching so that the first path is the column of squares, then shifted to match the branching of the colors. 4 path to 4paths.
@Rickson thank you very very much, but how can I organize it by floor? It is organized by squares of each floor
(when using match tree)
This is a great tutorial for understanding Data Trees.
