I accidentally disabled the zoom on my mouse wheel and I can’t get it back. I can no longer work if my zoom is disabled. I’m on Mac with a bluetooth mouse on a USB port. Thanks for your help.
Preferences > View, Zoom section.
You probably set your scale factor to 1.0
Try 0.95 instead.
Thanks for your answer.
Yesterday I changed the scale in 1 but also the grid option to 300. I change it this morning and the mouse wheel remains on rotation.
Hi Laureline -
Could you post a screenshot of the Preferences -> View
dialog?
Sorry for the late answer
Hi Laureline -
Which versions of both Rhino and macOS are you running?
Hy. This is my versions
Hi Laureline -
Thanks for that information.
I see that macOS 12.6 isn’t on the list of supported OS versions for Rhino 6, and, I suppose, there could be some incompatibility here.
I would try resetting all preferences to see if that helps - make sure to first export those preferences if you have modifications that you would like to keep → Rhino for Mac - Preferences [McNeel Wiki]
You could also download the evaluation version of Rhino to see if that fixes the issue.
What I don’t understand is that it worked very well before I changed the grid and the scale with this software.
I will update my Mac
After the last update of my mac is the same. Now it’s the 12.6.2 version. MONTEREY
Good news. After resetting the preferences all is correct. Have a good day.
