More unified mesh?
I’m a total newbie to Rhino so I need som help or at least be pointed in the right direction :slight_smile:
I wonder if there’s a way to make a mesh look more unified? As you can see, the models in green appears much more “clean” then the ones in red. Is there a good way to make the whole model look like the green buildings?
Hope this makes some sense
Thanks in advance!
Did you forget to attach images or a 3dm file to your message?
Yes I did :slight_smile:
You could use brep to mesh and custom mesh setting with a limit in max edge. See rightmost of mesh tab in grasshopper
