I was wondering if it would be possible for the rending wire frame options to be more like the rendered viewport display options. I really like to use a rendered viewport with surface edges (but not isocurves) visible. You get some shading but can still clearly see the geometry. In the render options, it’s only possible to turn on surface edges and isocurves. The workaround would be to dupBoarder on all the geometry and then turn on rendered curves, but that makes lots of geometry that I don’t really need. It could also be cool to make renderings with mesh edges or subD wires turned on. Not sure if anyone else would find this useful, but just a though.
Hi Andrew -
We have that feature request on the list as RH-59626. I’ve added your vote.
