Anyone have any suggestions on a monitor to buy for rhino, using the rtx 2000 graphics card. The computer manufacturer recommends a monitor with " mini display port" so no adaptors are needed. Very confusing to tell which monitors have a mini display port.
What? That’s the lamest possible criteria for picking out a monitor, do not use that. You can just use a cable that is mini at one end.
I had a 3x monitor setup for my workstation for years, with different sizes of monitors and resolutions throughout the years. A few years ago, I started to get headaches and neck stiffness after a short time in front of the monitors, so I had to make a major change. It dawned on me that I was sitting too close to my monitors. So, I bought a single 55-inch 8K LG TV that could be used as a monitor. (LG NanoCell NANO96 55" 8K) It only has a 60Hz refresh rate, but that is fine for me since I only use this setup for work-related tasks. Highly recommended. By far the best setup I have ever had.
