Hi-
Is there a way to modify an objects geometry while it is inside a block definition? I’m trying to clear the NGon list of meshes before they are exported. So far I have:
filt = Rhino.DocObjects.ObjectType.InstanceReference
rc, object = Rhino.Input.RhinoGet.GetOneObject('Get Block', True, filt)
if rc == Rhino.Commands.Result.Success:
blockInstance = object.Object()
blockObjs = blockInstance.InstanceDefinition.GetObjects()
for rhObj in blockObjs:
if rhObj.Geometry.ObjectType == Rhino.DocObjects.ObjectType.Mesh:
nGons = rhObj.MeshGeometry.Ngons
if len(nGons) > 0:
print 'NGons Found: ' + str(rhObj.Id)
nGons.Clear()
rhObj.CommitChanges()
Is there any way to get this to work or do I have to modify the mesh outside the block and then add it to instance definition.
Any help would be greatly appreciated!
