I want to get an object from a file and add it to the block definitions (I figured out how to do this). Then, I would like to add other obects to the block definition. This is what I’ve got so far (for an example). When I run it, I get an error saying that Breps do not have a Geometry attribute.
#! python3
import scriptcontext as sc
import Rhino.Geometry as rg
import Rhino
from Rhino import RhinoDoc as rdoc
block_name = rdoc.ActiveDoc.InstanceDefinitions.GetUnusedInstanceDefinitionName("torus")
path = "C:\\Users\\Owner\\Desktop\\torus.3dm"
torus_file = Rhino.FileIO.File3dm().Read(path)
torus = torus_file.Objects.FindByLayer('Default')[0]
index = rdoc.ActiveDoc.InstanceDefinitions.Add(block_name, "", rg.Plane.WorldXY.Origin, torus.Geometry, torus.Attributes)
sphere = rg.Sphere(rg.Plane.WorldXY.Origin, 1.2).ToBrep()
rdoc.ActiveDoc.InstanceDefinitions.ModifyGeometry(index, sphere.Geometry, sphere.Attributes)
# I would like this to have the torus and the sphere combined
sc.doc.Objects.Add(torus.Geometry, torus.Attributes)
Not sure why you are adding the objects from your instance definition separately.
I did that because I didn’t know about AddInstanceObject(). I’m glad you pointed this out, because this is exactly what I was looking for.
BTW, it takes a transform, not a point3d (I only realized after the Editor complained about it). But, in this case, I didn’t want to transform it. So, I tried to use Rhino.Geometry.Transform.Unset and Rhino.Geometry.Transform.ZeroTransformation. It ran without errors, but it did not actually add the objects to the document. So, I had to make my own dummy transform object. I ended up with this:
