Modifying the geometry of an object and maintain all other information
I’m trying to modify the underlying geometry of a referenced Rhino Geometry.
In this case a polyline, where I want the points of the polyline to move to new location.
I want to keep this simple, and I want the object to maintain all information (including ID if possible).
Now the code below is wrong, as I’m aware that the polyline I’m extracting is a new instance and not actually a reference the geometry of obj. But I hope it kind of shows what I want to do.
import Rhino
obj = Rhino.RhinoDoc.ActiveDoc.Objects.Find(x)
polyline= obj.Geometry.TryGetPolyline()[1]
polyline.SetAllX(5.0)
obj.Geometry = polyline
obj.CommitChanges()
obj.Geometry only allows me to get but not set.
I came across this comment from David, which, if I read it right, means that what I want to do is not directly possible, but what would be the best way around it?
I’m not the python expert here, but as far as I know, you have to:
  1. create a new instance of your geometry (you’re already doing so with:
  1. Use the ‘ObjectTable’ method ‘Replace’ (https://developer.rhino3d.com/api/rhinocommon/rhino.docobjects.tables.objecttable/replace), to assign the new geometry to the existing object.
It should just modify the geometry. Attributes of your RhinoObject should remain unchanged.
Something like this (not tested :grimacing:)
import Rhino
obj = Rhino.RhinoDoc.ActiveDoc.Objects.Find(objId)
polyline = obj.Geometry.TryGetPolyline()[1]
Rhino.RhinoDoc.ActiveDoc.Objects.Replace(objId, polyline)
Rhino.RhinoDoc.ActiveDoc.Views.Redraw()
This seems to be working!
Thank you.
Also it’s worth noting that ID, Attributes and everything remains with your method. Exactly what I was after!
Glad you achieved what you wanted! :slight_smile:
