Modify surfaces settings of display modes?
I have a difficult problem.
Which code function can modify the surface settings of view display modes’ objects?
Thanks,
A.
@dale , RhinoCommon have no DisplayAttributes Naked Edge Thickness and Surface Isocurve width, please added an issue for this. thanks
Hi @Alen_Russ,
i only see a display mode property for SurfaceEdgeThickness but nothing for naked edge thickness or isocurve width:
https://developer.rhino3d.com/api/RhinoCommon/html/Properties_T_Rhino_Display_DisplayPipelineAttributes.htm
import Rhino
import scriptcontext
def SurfaceEdgeThickness():
    dmd = scriptcontext.doc.Views.ActiveView.ActiveViewport.DisplayMode
    dmd.DisplayAttributes.SurfaceEdgeThickness = 3
    Rhino.Display.DisplayModeDescription.UpdateDisplayMode(dmd)
    scriptcontext.doc.Views.Redraw()
if __name__=="__main__":
_
c.
Yes, no naked edge thickness or isocurve width property
Thank you
I’ve logged the request.
https://mcneel.myjetbrains.com/youtrack/issue/RH-69035
– Dale
Thank you
