in this example i use 2 cylinders to do a boolean difference on a subd object. the result is 2 sockets in the subd part that has converted to a closed polysurface. Is there a way to put sockets in the subd part and it stay a subd?
test4.3dm (6.7 MB)
Hi David - in general no - as soon as a SubD is trimmed it must be converted to surfaces. You’d have to build that shape into the SubD structure, so to speak, not use trimming or Boolean operations.
thanks, that is what i would like to do is build that shape into the SubD structure.
I will work on an example to post back for you to look at, so you can see what I want.
i have trying to use this video to make it work what i want. the socket has to have a flat surface.
