I would like to modify the UI of the Status Bar.
Currently, I used a lot the “Layer Section” of the Status Bar, not only to sort thru layer but to also see what layer object I have selected are on.
However, the Layer Section is so small, that it usually does not show the full location of the object selected.
I wonder if there is a place in rhino where I can define the horizontal dimension of each section of the status bar.
Images below illustrating further:
Thank you in advance!
