I’m using the new Rhino 8 Material nodes to create custom materials from within GH but the features missing are being able to control the Roughness, Opacity/Transparency of said materials.
I am attempting to create a python node that modifies a PBR material from within GH but stuck with the method to actually find the referenced material.
You can see below I’m taking a new model material, getting its ID, and giving that to python to then find that material and set Material Attributes from my python inputs (color, sliders, etc). (Or at least this is what I am trying to create.
Here’s a snip of the graph:
Here’s the baked result (Roughness always gets set to 100):
Here’s the intended result (Roughness gets set to user defined value from GH):
The “Create Material” component can influence the opacity from GH but cannot influence Roughness
Here is the code thus far:
import random
import Rhino
import scriptcontext as sc
import Rhino.Render as rr
import System.Drawing as sd
def set_material_parameters(material_name, diffuse, roughness, opacity):
rhino_doc = sc.doc
render_materials = rhino_doc.RenderMaterials
material_index = None
for i in range(render_materials.Count):
material = render_materials[i]
if material.Name == material_name:
material_index = i
break
if material_index is not None:
# Get the current material name
current_name = rs.MaterialName(material_index)
# Set the new material name
previous_name = rs.MaterialName(material_index, "Your New Material Name")
material = render_materials[material_index]
material.BeginChange(rr.RenderContent.ChangeContexts.Program)
# Set diffuse color
material.SetParameter("diffuse", sd.Color.FromArgb(diffuse[0], diffuse[1], diffuse[2]))
# Set roughness
material.SetParameter("roughness", roughness)
# Set opacity
material.SetParameter("opacity", opacity)
material.EndChange()
else:
print("Material not found!")
# Input parameters
material_name = "Your Material Name" # Input material name as a string
diffuse = Diffuse
roughness = Roughness
opacity = Opacity
#print diffuse
#print roughness
#print opacity
Thank you for your help and any leads! Always appreciated!
