when creating custom materials i´d like to have rough/polished value as you get with the metal material in Rhino.
i can not find a property like that. i tried “shine” but that does not seem to do anything.
how would i create something like the rhino metal materials myself? Is that an extra class i did not find?
If you use RenderMaterial to create a new material, then you can set the parameters "shine" and "polish-amount" to your wanted value (in the range [0.00,1.00]).
For a metal to be a metal with the custom rendermaterial you need to have diffuse color set to black and reflectivity to 1.
To check the names you should fiddle with you can save a material to file and open it in a text editor. I like to create a metal first, then convert it to custom, and save that out. Open up and look at the <parameters> section.
How are you currently creating your materials? (Code snippet please).
hi @nathanletwory
here is the code:
var custom = new Rhino.DocObjects.Material();
custom.Reflectivity = 1;
custom.ReflectionColor = System.Drawing.Color.FromArgb(r[currIntOption], g[currIntOption], b[currIntOption]);
custom.Transparency = fjMatTrans[currIntOption];
custom.Shine = fjMatShine[currIntOption];
custom.Name = matName[currIntOption];
custom.CommitChanges();
rm = RenderMaterial.CreateBasicMaterial(custom);
are “shine” and “polish-amount” two different properties?
There seems to be a difference between “Material” and “RenderMaterial” that i don’t get. Are they connected? Do i have to use both like i do in my code?
Rhino.DocObjects.Material is the old-style material. Rhino.Render.RenderMaterial is the new-style RDK material. I’d advise RenderMaterial over Material.
Here is a snippet in Python to create 10 metal materials with random roughness. Shine and Polish Amount are the inverse of roughness, so for a perfectly smooth metal you’d pass in 1.0 to both.
# Create 10 random metal-like materials
# using RenderMaterial
import Rhino
import System
import scriptcontext
import random
for i in range(0,10):
m = Rhino.DocObjects.Material()
m.Name = "Random Roughness Metal"
shine = random.random()
rm = Rhino.Render.RenderMaterial.CreateBasicMaterial(m)
rm.BeginChange(Rhino.Render.RenderContent.ChangeContexts.Program)
rm.SetParameter("diffuse", System.Drawing.Color.Black)
rm.SetParameter("reflectivity", 1.0)
rm.SetParameter("reflectivity-color", System.Drawing.Color.LightBlue)
rm.SetParameter("shine", shine)
rm.SetParameter("polish-amount", shine)
rm.EndChange()
scriptcontext.doc.RenderMaterials.Add(rm)
A test run yields:
hi @nathanletwory
thank you very much! this helps a lot!
Hi Nathan,
I took your script as a basis to modify.
I can’t to assign a value of 50 for “shine”, but If I remove the line for i in range(0,10) then script stops working.
I managed to turn on the ChildSlot for the Environment, but I can’t assign a bitmap.
Do not scold much. I’m at the beginning of the way.
import System
import Rhino.Display
import Rhino.Render
import random
for i in range(1,2):
m.Name = "New"
context = Rhino.Render.RenderContent.ChangeContexts.Program
rm.SetParameter("diffuse", Rhino.Display.Color4f(0.64,0.92,1,1))
rm.SetChildSlotOn("shine", True, context)
rm.SetParameter("shine", 50, context)
rm.SetParameter("reflectivity", 0)
rm.SetParameter("transparency", 0)
rm.SetChildSlotAmount("environment-texture", 30, context)
rm.SetParameter("environment-texture-on", True, context)
rm.SetParameter("filename", r"C:\Program Files\Rhino 7\System\rhino_shaded_mode_emap_background.png")
rm.EndChange()
You should put a number between 0.0 and 1.0. 1.0 equates to 100 in the GUI, so use 0.5 for 50.
Thanks - I have done as you suggest. It woks.
How to assign an Environment map?
You can check this tutorial: https://jesterking.github.io/rhipy/create_pbr_material_with_textures.html
Thank you but I can’t deal with it yet.
It doesn’t look like a script that I work on.
Completely different style and data types.
I opened the material with the environment in the text editor.
What to take for current script to assign an environment map?
I tried take different parts, but the environment map still not assigned.
Is missing type=string
<environment-texture type=string>C:\Program Files\Rhino 7\System\rhino_shaded_mode_emap_background.png</environment-texture>
<environment-texture-on type=bool>true</environment-texture-on>
<environment-texture-double-amount type=double>0.3</environment-texture-double-amount>
<environment-texture-amount type=double>0.3</environment-texture-amount>
and without environment.
<environment-texture type=/>|
<environment-texture-on type=bool>true</environment-texture-on>|
<environment-texture-double-amount type=double>0.3</environment-texture-double-amount>|
<environment-texture-amount type=double>0.3</environment-texture-amount>|
How add it to current script?
I tried to repeat your script, but for crate BasicMaterialType it not suitable. I tripped on pbr = sim.BasicMaterial
PBR is not supported it. I need the Custom material.
BasicMaterialType
import Rhino as rh
import Rhino.Render as rr
import Rhino.DocObjects as rd
import scriptcontext as sc
bitmap_texture_type_guid = rr.ContentUuids.BitmapTextureType
pbr_material_type_guid = rr.ContentUuids.BasicMaterialType
bmtex = rr.RenderContentType.NewContentFromTypeId(bitmap_texture_type_guid)
bmtex.Filename = "C:\Program Files\Rhino 7\System\rhino_shaded_mode_emap_background.png"
simtex = bmtex.SimulatedTexture(rr.RenderTexture.TextureGeneration.Allow)
pbr_rm = rr.RenderContentType.NewContentFromTypeId(pbr_material_type_guid)
sim = pbr_rm.SimulatedMaterial(rr.RenderTexture.TextureGeneration.Allow)
pbr = sim.BasicMaterial........
Then I took your lesson “How To Change a Material By Code” on YouTube about ToString.
But the script doesn’t start.
Convert.ToString
import Rhino as rh
import System
import Rhino.Render
import random
rm = [m for m in sc.doc.RenderMaterials][0]
m.Name = "New"
print(System.Convert.ToString(rm.GetParameter("environment-texture")))
print(System.Convert.ToInt32(rm.GetParameter("version")))
rm.SetParameter("version", 2)
rm.SetParameter("shine", 0.5, context)
rm.EndChange()
