Im broken, im downed, pls Help
I want to drape the following surface over a frame
its suposed to hang through the frame like its doing in the model photo!
If someone does know how to do this i would appreciate help
Hello Tibor,
Please post the model if you can.
Thank you,
Andy
Okay
pls help.3dm (3.0 MB)
Are you using R8?
Hello Tibor,
The file is R8. Should you need a different version please let me know. I copy/pasted the whole model into a new file where the units are in cm [small objects template- imagine for this model it could be the large objects template].
Then moved the two objects to the origin from as close as I could get the same place on each object.
I did not do anymore because it is not clear to me exactly what you want. However, the two objects are now pretty closely aliened. There are a number of ways- commands to use- to be precise but to do so I would need to make some changes to the objects [not their geometry but rather their nature].
So hope this helps you. If not, please just post such. And or if you want to describe in more detail [and diagramming helps too] the next step given trouble; please post this matter as well.
Thank you,
Andy
pls help_.3dm (518.4 KB)
