all you need is the outlines of it, split the ground curve in half as seen on the picture the other you keep as a whole. use Sweep2 selecting both split curves and choose a point at one end then the crosssection then again a point at the other end and execute.
oh and forgot to add: if you switch on history you can change the shape through the initial profile curves and will see the update immediately. just see that the curves meet each other when you change them otherwise it may rip the sweep apart.
@Chixt another good way to make this sort of ‘smooth pebble’ shape is to loft a set of mathing curves ‘Loose’ You can end the loft at a point as I did here or along the edge of a center surface.SoftShape2.3dm (83.7 KB)
