Model is slow, why?
Why is the model slow ? Because of my computer ? Or too much Meshes ?
Facade skin.3dm (4.8 MB)
Run systemInfo command in rhino. Send us the results.
Generally display and navigation on my computer is not slow. The testmaxspeed command results in 1.64 seconds.
Is there something specific that seems slow?
The file has 11 million mesh faces in it. This can be a challenge for some video cards that perhaps are also running multiple large monitors.
11 million ? It must be too heavy for my computer i think. Thank you for helping.
Rhino 7 SR38 2024-12-3 (Rhino 7, 7.38.24338.17001, Git hash:master @ 97e36efa02d7f71638988290bb2d190fcf1b18c5)
License type: Commercial, build 2024-12-03
License details: Stand-Alone
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 32Gb)
Primary display and OpenGL: Intel(R) Iris(R) Xe Graphics (Intel) Memory: 1GB, Driver date: 6-1-2021 (M-D-Y). OpenGL Ver: 4.6.0 - Build 27.20.100.9664
Integrated graphics device with 4 adapter port(s)
  • Windows Main Display is laptop’s integrated screen or built-in port
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Vendor Name: Intel
Render version: 4.6
Shading Language: 4.60 - Build 27.20.100.9664
Driver Date: 6-1-2021
Driver Version: 27.20.100.9664
Z-Buffer depth: 24 bits
Total Video Memory: 1 GB
C:\Users\bilan\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\LookXRender\1.0.1\LookXRender.rhp “LookXRender” 1.0.1.0
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.38.24338.17001
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.38.24338.17001
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.38.24338.17001
C:\Users\bilan\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\PanelingTools\2021.3.2.446\PanelingTools.rhp “PanelingTools”
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.38.24338.17001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.38.24338.17001
Ok,
  1. This is Rhino 7. It will slow down with lots of Blocks. All of these objects are blocks within blocks. So that is part of the problem. Exploding the blocks may help. V8 fixed much of this problem.
  2. Yes the video on the machine is quite small, below recommended. Having 4GB video memory we would consider minimum,
A way to cheat on this would be to explode all the blocks and join everything into one mesh. I expect that might be able to display much faster.
