Mixing visibility
Is it possible to mix visibility in one viewport? to set some objects to ghosted while others are wire frame? thanks
Hi @ethank
setobjectdisplaymode is what you’re looking for, I think :smile:
HTH, Jakob
thanks Jakob Ill give that a try!
so it seems that this command works just for view your in. so if i want the object display mode changed in all views i need to go through each and every view? Is there a way around this?
@ethank,
I believe there was a post regarding this issue, yet I could not retrieve it. Though I have the file, its not mine… its a python script. If I remember correctly @Helvetosaur made the script
/\ Matthijs
SetObjDisplayModeAllViewports.py (1.7 KB)
THANKS for sharing
