I am developing a 64 bits plugin for Rhino 5 with VS 2010 and the C++ SDK. I followed the instructions given on the following page:
But when I press the “Start Debugging” button, then I get the following error messages:
“Debugging information for ‘Rhino5x64_d.exe’ cannot be found or does not match. Cannot find or open the PDB file”
“‘Rhino5x64_d.exe’: Loaded ‘C:\Program Files (x86)\Rhino 5.0 x64 SDK\Bin\x64\Rhino5x64_d.exe’, Cannot find or open the PDB file”
“‘Rhino5x64_d.exe’: Loaded ‘C:\Windows\System32\ntdll.dll’, Cannot find or open the PDB file”
… and many others
It seems that PDB files are missing in my Rhino installation. Has anyone had this problem before?
Thanks
dale
(Dale Fugier)
January 25, 2018, 6:40pm
2
Hi @Guillaume ,
Please review the following SDK guide regarding plug-in build configurations and let me know if you have any questions.
– Dale
Hello Dale,
I have Rhino 5 SR14 64-bit. I downloaded the SDK a few days ago from this webpage:
https://www.rhino3d.com/download/rhino-sdk/5.0/release
I see the installer is called “rh50sdk_5.9.40609.20145.msi”, so I suppose it is like version 5 SR9 ? According to the link you sent, this might be the problem. How can I get consistent version of Rhino and SDK ?
Thanks
dale
(Dale Fugier)
January 25, 2018, 7:38pm
4
Hi @Guillaume ,
The easiest thing to do is build using the PseudoDebug configuration. You can debug with this build type.
– Dale
Hello Dale,
Unfortunately, the PseudoDebug mode is also not working. I get the error message "cannot open file path\pluginname.rhp’.
Is anything else I could try to use Debug or PseudoDebug mode ?
Regards,
Guillaume
dale
(Dale Fugier)
April 12, 2018, 9:04pm
6
Hi @Guillaume ,
Set you debug target to Rhino.exe.
– Dale
dale
(Dale Fugier)
April 12, 2018, 10:02pm
8
When do you get this message? How can I repeat what you are seeing?
– Dale
When I build the project I obtain the following warnings and errors:
dale
(Dale Fugier)
April 12, 2018, 10:54pm
10
Hi @Guillaume ,
You can get “cannot open” and “acces to {path} denied” when building if you plug-in .RHP file is already in use by a running Rhino.
If this isn’t the case, then you might check the .rhp file and make sure it’s not tagged as read-only.
– Dale
Hmmm … Now it builds but I come back to my original problem when I press the “start debugging” button:
dale
(Dale Fugier)
April 12, 2018, 11:15pm
12
Check the “Don’t show this dialog” again, and continue on…
