moral.ts
(Moral Ts)
June 10, 2020, 9:30am
1
So I’m using Pipe command for my work, and some options I had are missing:
Command: Pipe
Select rail ( ChainEdges Multiple )
Diameter for closed pipe <8.00> ( Radius ShapeBlending=Local FitRail=No )
I have these option. Because I want to make the object thick, I need to have the options for Thick and Cap, which are missing.
How can you help me solve this issue?
Warm regards
That looks odd - “Diameter for closed pipe” is not the standard prompt at the command line after selecting the rail, it should ask you for the start radius. Is this the native Rhino Pipe command, or some custom script/plug-in?
Can you run SystemInfo in Rhino and copy/paste the results here?
moral.ts
(Moral Ts)
June 10, 2020, 10:55am
3
The rail is a closed curve, but when I split the shape I want to be able to choose the thickness of the pipe.
Here’s the SystemInfo:
Rhino 6 SR26 2020-5-26 (Rhino 6, 6.26.20147.06511, Git hash:master @ 7788f6214ee9335d5793cc6177985a1c745e663b)
License type: Educational, build 2020-05-26
License details: Cloud Zoo. In use by:
Windows 10.0 SR0.0 or greater (Physical RAM: 7.9Gb)
Machine name:
Hybrid graphics system.
Primary display: Intel® UHD Graphics 630 (Intel) Memory: 1GB, Driver date: 9-25-2019 (M-D-Y).
Primary OpenGL: NVIDIA GeForce GTX 1050 (NVidia) Memory: 4GB, Driver date: 9-8-2019 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 431.91
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 9-8-2019
Driver Version: 26.21.14.3191
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
Rhino plugins
C:\Program Files\Rhino 6\Plug-ins\Commands.rhp “Commands” 6.26.20147.6511
C:\Program Files\Rhino 6\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 6.26.20147.6511
C:\Program Files\Rhino 6\Plug-ins\RhinoCycles.rhp “RhinoCycles” 6.26.20147.6511
C:\Program Files\Rhino 6\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 6.26.20147.6511
moral.ts
(Moral Ts)
June 10, 2020, 11:10am
4
hi
I solved the issue thank you very much for your help.
I thought I will be able to make the closed pipe solid.
I figured that I can do thickness only with an open curve.
בתאריך יום ד׳, 10 ביוני 2020 ב-12:48 מאת Helvetosaur via McNeel Forum <mcneel@discoursemail.com >:
moral.ts
(Moral Ts)
June 10, 2020, 11:11am
5
hi
Ah, yes, using a closed curve, totally spaced that one, sorry.
