Material library and Template is missing, even Rihno 8 has been downloaded and reinstalled 5 times.
Hi Ali, please run systeminfo command in Rhino and post the result. Have you tried Repair? Go to Add or Remove Programs and Modify the Rhino 8 install to Repair.
Thanks anyway, I solved that by the Rihno 8 factory Rest, but problem is crashing of Rihno by attempting to assign material to a surface.
Hej Ali -
Does the crash reporter dialog pop up when Rhino crashes? If so, please always send those in. As of now, I’m not seeing any such reports from your account.
Apart from that, please run the Rhino SysrtemInfo command and copy-paste its output here.
Thanks
her is it.
Rhino 8 SR20 2025-6-6 (Rhino 8, 8.20.25157.13001, Git hash:master @ 73b00899cf43922900a763212f167c03dc6f27cc)
License type: Evaluation, build 2025-06-06
License details: Stand-Alone
Expires on: 2025-09-08
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 8GB)
.NET 8.0.14
Primary display and OpenGL: Intel(R) HD Graphics Family (Intel) Memory: 1GB, Driver date: 3-28-2017 (M-D-Y). OpenGL Ver: 4.3.0 - Build 20.19.15.4642
Primary OpenGL: Intel(R) HD Graphics Family (Intel) Memory: 1GB, Driver date: 3-28-2017 (M-D-Y). OpenGL Ver: 4.3.0 - Build 20.19.15.4642
> Integrated (slow!) graphics device with 3 adapter port(s)
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Graphics level being used: OpenGL 4.3 (primary GPU’s maximum)
Anti-alias mode: 4x
Mip Map Filtering: Linear
Vendor Name: Intel
Render version: 4.3
Shading Language: 4.30 - Build 20.19.15.4642
Driver Date: 3-28-2017
Driver Version: 20.19.15.4642
Z-Buffer depth: 24 bits
Total Video Memory: 1 GB
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.20.25157.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.20.25157.13001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.20.25157.13001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.20.25157.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.20.25157.13001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.20.25157.13001
Hi
Okay.
No it dose’t report any, Rihno just turns Off.
Hej Ali -
I’m afraid you won’t get very far with that onboard GPU. We recommend a dedicated GPU having at least 4 GB of VRAM per monitor for running Rhino 8. You might not have issues drawing shapes and such in wireframe and shaded modes, but - as you see - rendering features will be problematic to the point where it simply doesn’t work.
You could try finding more up-to-date drivers for that Intel card… Open the Notifications panel in Rhino and follow the links from there.
