having a little tiny trouble with hatch match in the hatching dialogue box. The hatch is working well with all the properties of the parent object, except for the layer that it is located in, even when you change the toggle to match layer. Maybe i am doing it wrong, because it seems so obvious.
Apparently, it isn’t equally obvious for all users. As it is now, only properties that are specific to hatch objects are being matched when using that button. It would appear that 50% of the users expect it to behave like that…
For the time being, you can create a “dummy” hatch and then either use the MatchProperties command or use the Match button on the “Object” page in the Properties panel.
Having a dummy Hatch can work, but it does break up the workflow. I was expecting to do all the changes in the hatch panel. Also, I don’t use match properties too much anyhow. Typically, I set up detailed layers so i can move each object to a certain layer & that way I know all the object properties are inherited.
