As my title says. It would be great that I could use the MatchProperties command with hatches. At the moment only the layer and the layer color are the only properties matched. Would it be possible to add to the list the following:
just select the hatches you want and go to properties and hatch section (as seen below) press this button it will ask your reference hatch its all done
hope it is what you want but i agree with you “match” command can match hatch properties at least we should check uncheck it
That is what I was after. But doesn’t it make sense to have it as a command?
I mainly use the command line that is why I missed it. or is there a command for this?
+1
I use MatchProperties when I want objects to match completely, including Match in the hatch panel.
Also,
match texture mapping - that’s another thing I often match manually while using MatchProperties.
