Millipede grasshopper
I am trying to do topology optmization in millipede but it keeps give me nothing as a result . Anyone know where is the problem?
https://discourse.mcneel.com/t/how-to-ask-effective-questions/50034/2
Nehalnasser,
Could you try feeding a few more inputs into your solver:
  • The optimization iterations
  • Smoothing
  • Target density
Then upload your file.
Drew
When you downloaded Millipede it came with example files as well as a plugin overview pdf, make sure to look through the pdf together with the example files. The documentation in that pdf is pretty good and should help you get the hang of how the solver works.
Hello. I was searching for example files, but had no success. May be you can upload it?
