How to ask effective questions
Asking questions and getting answers is what this forum is all about. Although people are generally very helpful, there are things you can do to improve your chances of getting good and quick answers. Below you will find some suggestions, but don’t think of them as rules and especially don’t think of them as guarantees.
1. Choose a descriptive title for your post
Don’t title your question Help! or I have a problem or Deadline tonight!, but actually describe the problem you are having.
2. Be succinct but clear in your wording
People need to know some details about your problem in order to understand what sort of answers would satisfy you, but nobody cares about how angry your boss or how bad your teacher or how tight your deadline is. Talk about the problem and only the problem. If you don’t speak English well, you should probably post in your native language as well as providing a Google or DeepL translation of your question.
3. Attach minimal versions of all the relevant files
If you have a gh file you have a question about, attach it to the post. Do not expect that people will recreate a file based on a screen-shot because that’s a lot of pointless work. It’s also a good idea to remove everything non-essential from a gh file. You can use the Internalise Data menu option to cut everything to the left of a parameter:
If you are referencing curves or breps or meshes from Rhino, you can also internalise them so you won’t have to post a 3dm file as well as a gh file. If you’re unsure whether all the relevant data is internal to the gh file, try opening it in an empty Rhino. Does it work? Good. No? You’ll need to internalise more.
4. Include a detailed image of the file if it makes sense
If your question is about a specific (group of) components, consider adding a screenshot of the file in the text of the post. You can use the Ctrl+Shift+Q feature in Grasshopper to quickly create nice screenshots with focus rectangles and embedded viewports such as this:
5. Include links to online resources if possible
If you have a question about Schwarz Minimal surfaces, please link to a website which talks about these.
6. Create new topics rather than continuing old ones
It’s usually better to start a fresh question, even if there’s already a discussion that kinda sorta tangentially touches upon the same issue. Please link to that discussion, but start anew.
7. This is not a do-my-work-for-me group
Many of us like to help, but it’s good to see effort on our part being matched by effort on your part. Questions in the form of “I need to do X but cannot be bothered to try and learn the software” will (and should) go unanswered.
Similarly, questions in the form of “How do I quickly recreate this facade that took a team of skilled professionals four months to figure out?” have a very low success rate.
Help with modeling this
How to change start and end of the curve(open)
Moderators
Split data
Assign geometry (cross) to series of points
Geodesic lines on a Mesh
I need help for a job at the university
Drawing patterns
Mesh to Brep?
Herzog & de meuron building
From the true&false list, I would like to check if there is the true element"
How can I make this pattern?
Sweep 1 - Multiple section curves in both ends of multiple rail curves
Grasshopper
Extrude 2 d image automatically
Errors of components in grasshopper
Opacity Gradient from Attractor Point
Creating spiral flowers that can open up
The direction of curves on surface
Multiple point attractors
How to make this surface?
Python Simple problem boolean difference loop
How to read the numeric data out of the image sampler
Loft in Grasshopper works different to the loft in Rhino?
Finding the difference between two sets of referenced geometries
I want to line up a bunch of irregular holes and use them for processing
Paneling a free-form surface with Same squares
Control Spacing of circles in Hex Grid
Display item /data conversion failed text to surface-How can I replace items with making it to text?
How to create macro to Convert any suface to patched surface
Interpcurve
Extracting row/columns on a grid of points
Get intersection indices
Geometry is not moving to the correct position
Move two points by their respective directional vectors to a fixed offset distance from a line?
Mover o dividir curva en dos longitudes o 2 distancias diferentes en forma de serie
Wrap a surface on a volume
Pufferfish - Tween 'Implicitly'
How to extract the coplanar extraction of 2 groups of irregular cubes
Parametric brick pattern
How to close out curve made from "Divide Curve"
How to convert brep from loft to surface and divide into panels and provide mechanism component
Create outside surface from lattice structure
Failure in a section follows shapes
Creating a circular, hexagonal fading pattern with paneling tools curve attractor
Metal pavilion design
How make hole? (Porosity)
Sphere pattern strips
Conic SPM structure: evaluate surface
Ask for divide the curve by list of numbers
Arrange brick along Circle
How to Create the first Scherk Surface
Can't Find Grasshopper Component
Tapered extrusions non planar curves
Intent failure of flow parameter
Creating joints between pipes for 3d printing
How could I make a maze cube on Grasshopper?
Extending a Mesh to a Curve
Rename text with grasshopper
Avoid overlap between surfaces
Draw line between points(problem solved)
How to create this paneling using Grasshopper
Grasshopper- How to 3D panel on surfaces going in a certain direction
Grasshopper truss beam
Attractor crvs for multiple crvs
Joining Brep-Tiles via Connectivity
Pursuit curvature pillars
Rotational Analysis For Brick Facade
Voronoi (3D) Ring
Extrude polylines with point cloud
How to generate random 2D shapes with random angles and curves as sides?
Basic tutorial for 3D mesh structures
Curve Diagrid Lines
Private void RunScript error
Multiply sections from one script
Texture leaves
Intersection points over surface from which perpendicular lines start
Organic tree parametric skyscrapper - guidence needed
Mesh/Surface/Curves from 3dGrid
How to get support on the ShapeDiver forum
Trim a line
Noob question #004? immutable objects
Script for wood pattern
Unable to convert Surface to Brep Geometry?
Delete informations from a panel
3d textures on lofted surface
Getting bounding curves from a cell?
Use A-Star Algorithm (Shortest Path) in a 3D environment (networkx module)
Any interpretation for the Lisbon Oriente Station?
Elefront:Define multiple blocks from a list of breps/geometries
Figuring out what kind of surface I have?
Issue Timer Component
How do I re-create a similar structure like this, porous architecture
Grasshopper Shoebox model
Distribute / Orient on surface
Loft curves
Unfolding sheet metal
How to make like these images' facade
Trouble importing .wrl file
Type Create
Duplicate lines in rhino
Move multiple groups to closest point
C# Grasshopper how to handle with combobox
Improve the previous Design Honeycomb structure
Problem with scaling of BREP: keeping the upper part
How to group same points from different branches within the same tree and not loose the path information?
Optimization of diagonals in truss structures
Change text to a number
Indexing a point list in python component
Asking efficient questions Grasshopper?
Dividing Surface distortion!
Sweep beam
Creating Surfaces Between Lines
Design honeycomb structure
Using of Scale NU - keeping the upper part instead of the bottom part
1st day at Grasshopper, orientation question
Selecting surfaces on similar or identical centroids
Waffle structure not aligned
Gridstructur with certain line lenght
Contour along curve
Wave-like surface definition
Connecting points on two different curves using path mapper
Offset trim and fillet curves
How to make this structures? And more like this
Gradient Diagrid with Lunchbox
How to move brep
Sequencing of curves
Rotate multiple elements randomly around own centre
Sweep Profile on Tween Curves just once
Add items to branches of a tree
Split polysurface into halves
Image sampler
Simple Parametric Human Body
How to solve the problem with the exoskeleton and curves
Blending meshes
Can anyone help me with this texture
Create such a this pattern in grasshopper
Brep - Brep list intersection
I would like to print Nylon and FPE by G-Code .. someone can help me with the setting of the G-CODE?
Can you help me (image sampler)
Smoke effect
Help with grasshopper/rhino
Transform and remove original geometry
The file what I recieved from the consultant company .it looks like this.why?
How to make a minimal surface?
Help sos! from grasshopper to rhino
Move point
Replace self intersecting curve
Select closed curves by area
Attractor curve
Extruding height from excel data on grasshopper
BMW Vision next 100
How to create a rotating mesh with grasshopper for population?
Help to a grasshopper newbie to create a text output please
Recommendation for organizing pieces for laser cutting
Copy element in center of hexagon
Help parametric design
Voronoi and then offset error
I want to do this
How to Optimize Floor Space
Latitude / Longitude Drone flight recording to Node / flight path & more
Italian Pavilion Expo
How to create a random volum?
Https://discourse.mcneel.com/t/rhino-6sr10-the-block-command-does-not-apply-to-vray-light-vray3-6-3/73622
Wave louver facade with multiple attactor curves
V-Ray + Grasshopper Scatter for more than one surface
HELP with Freeform Roof Structure
Hexagon Grasshopper
Merge overlapped (colinear) curves to single one
Customizing the transform/morph/surface box
Help with fillet on planar geometry
Voronoi wont project onto a surface; Help
Ruled Surface between two curves
Voronoi with attractor points gh surface
Guidance in trimming shape
Evolute Tools Expert: Is there an evolute tools expert to refer from?
Connection Problem line-surface in Rhino 6 with Karamba
Repeated rotations
Matching components
How to populate text from Grasshoper to Rhino?
Replacing points depending on size of original list HELP WITH INDEX
Does anyone have any scripts that are similar to this? Struggling to wrap my head around it
How to attach random geometries to the panel grid?
How to scale in different ways
Join lines, sequence incorrect. Lofting gets messy
Scaling Multiple Circles from Centerpoint
Loft problem
I broke the NumberSlider
Rhino export to cad, hatch has no area info
Orient rectangular to line direction
Convert mesh to surface
Offsetting points along individual plans
URGENT: Grid on trimmed surface
Removing surfaces
Grouped Text with a closed curve from Rhino in Grasshopper
Multiplying indexes in Relative Item offset
What is the best way to close hole in mesh?
Voronoi curve trim with surface
Join independent polygons simultaneously
GH Python in Rhino 6 - Vicarious Argument
Filter Circle with Diameter/Radius smaller than
Created MOSAIC
Loft with radius
How to grasshopper this effect?
Horizontal frames divisons
Tangent , between to different shape (surface )
Intersection for two curves
Honeycomb Definition
Panels on a double curve surface
Automating grasshopper / rhino from command line with arguments?
Created script to do 2D Mosaic
Selection Filter
How to set joine rhinosurfaces in to grasshopper surface
Bool stack of boxes with one object
Loft of several curves
Make curves equal of Pyramid cone
Item lists
Pattern attraction/repulsion along curve
Delete duplicated points
Sort duplicate values
Creating triangular grid from existing list of points
Multiple list with vector
Lofting two rectangles correctly
Unwanted Points after Move component
Locally transform multiple meshes
Help (optimize solar radiation & day light &wind)
Import coordinates from an excel file
Honeybee failed to download the files needed to run EnergyPlus with Openstudio error
Runtime error (IndexOutOfRangeException): index out of range: 0 Traceback: line 3, in script
Please help me regarding the OpenStudio error, I have a deadline
Orient multiple solids to a CPlane
HoneyBee: OpenStudio error
Lunchbox paneling on multiple surfaces
Grasshopper is slow
Black, yellow, and red dot appearing in render window!
Colorizing pointclouds
Colour Gradient - Above and below 1?
Gradually increase distances between elements in Z direction?
Accessing Specific Information From a List (Multiple Times)
Ladybug, Radiation Analysis to design Louver
How to recreate the facade on ZAHA’s Innovation Tower?
How to spread curves for laser cutting
Attractors exercise in Grasshopper Primer
Extrude object along two curves
Flow along surface problem
Replace line with curve
GH Python - Intersect List of Curves and get a List of Point3D
Cull Index Issue - List Item 0 Gives weird Integer
Subtract a list from another bigger one
Perforated sheet
Creating one clean surface from multiple overlapping surfaces!
Elliptical wing trouble for RC glider
Nesting laser cut lay out
Variable Mesh Edges Thickness (Horizontal, Vertical, Diagonals)
How to grow/expand curves (polygons) until touch each other
Thickening multiple surfaces / mesh
How to close a volume?
Window color scheme
Optimizing panel arrangement
How to join edges visual gaps of surfaces
Problems with attractor point catchment area - overlapping catchment areas
Flipping line order
Simple things are hard for me to do
Color coding by Gradient a group of surfaces by height of their apex
Hexagon.turn
Edit a mesh
This form is how to do?
Which component will be helpfull or the ideal to do this?
Tributary area of a beam/line in GH
How to connect At-tractor points to Geometry
Closed Curve as boundary for random points on a plane
Code exist for smallest curve between two points with slope?
Joining two surfaces at a point
Allign geometry to xy plane
Can't get Region Union or Solid Union to work on these curves
Remove duplicate geometries
Roofing structure
Resizing and fitting a group of rectangles so that they do not leave any space in between each other
Unrealistic Energy simulation values
How to pixelate a form in grasshopper
Surface between lofts
Creating a grasshopper pattern
Rotate a grid inside a surface/mesh
Soft morphable solid?
Vb script unroll
Creating multiple surfaces
Mesh Definition from grasshopper intralaticce
Parametrice this
Looking for low latency reading and writing of large data sets from Excel
Streets growing into a Tower
Trouble with triangular surfaces and lunch box
Wanted to make a cloth/fabric surface on top of a brep
Insufficient faces in the x-direction
Divide surface by distance
How to select only the end points?
Copy Brep to points and rotate them toward a central point
Create diagonal list of points
How i can make this
(HELP) Making Inflatable facade by Grasshopper
Reorganizing tree branches by z factor domain
How to change the list of an area?
Rhino Grasshopper Run Error
Help me trim that surface
HELP - New forms
How to make rocking chair?
Curve side works not correct
Please tell me how to fix it :(
Fabric like pattern on facade!
Create surface between polylines or points
Create a list of points with same z coordinates
Boolean Union Set doesn't work
Triangular grid with equilateral triangles without the excess trims at the boundaries
Help please ABOUT GRASSHOPER! SOLVED
Rhombus - curves
Line attract point problem
Finding intersection points
Biomorpher Plugin
Mesh from Lines
List management
Grasshopper triangular wall
How to sort list of surfaces by number of vertices?
Mascara Brush
Need some Help!
HEY, Could this design that consists of this concept be made in grasshoper?
Rotate 3D multiple plane, and there are some randomly rotate upside down
Project curves or surfaces to XY plane for Laser Cut?
Deconstruct Brep Adds more Surface
Python linking grasshopper with Etabs api
Replace number with given numbers
Attractor curve that affects the space between objects
Triangulate loft
Big VB component (involuntarily) runs in a loop
SpinForce Issue
Hexagonal Grid on 3D Curved Surface
GH help? voronoi
Basic python code - how to wrap value in "for i in" loop with conditional?
Different Cull Pattern For Each Branch Of A Tree
How to use Deconstruct Face
How to Connect Points from 3 Data Sets
Bulge Brep
Vectors don't go around spin forces
Create surface by loft of curves having problems with wild curves in some parts
Repeat Same Surface Without Copying
Surface order
Proximity HELP please
Prevent pipe breaks?
Orient curve
Rotation of Lines with limited Range of Radius
Asking for help, question of array
Density map of Points in Grasshopper
Creating surface from hexagonal grid
How can I tag and label beams in triangle grid?
Shuffling length values ,grasshopper
Geometry multiplication along surface
Control the angles of voronoi on grasshopper
Proximity 3D analysis between two surfaces (mesh)
Check whether the polygon(curve) is within the boundary
Random lists of numbers from a data pool
Daylight optimization using Hobeybee and Galapagos
Help! GH for historical Architecture
How to use Elk to extract building heights
Parametric spiral staircase
How should I go about trimming several triangles out of this trangulated surface?
Definition for Facade Panelization
How to deform a solid that is part of a grid that has been adjusted using attractor points
Expression problem
How to create such reliefs, patterns?
Sunlight hours analysis provides an error
Galapagos, Skipping some cases
Surfaces have different uv values
Create a delaunay mesh from evaluate surface
Variable Piping Multiple Curves with Curve Attractor
Shatter component / Crv-Crv intersection: does not always work
Subdivide Surface by Repeating Module
Closest points with same distance issue
Won't machine a simple slot [RhinoCam]
How can I group points by their Z value and draw a nurbs curve between them?
Why is there a problem with the distribution of the points of the front line and the last line of my line?
Is there a way to analyse a [dens] mesh for 3D printing compatibility?
Remove points out a brep or keeping only on brep
Create solids from curves
Grasshopper
How to change all axis of lines to be the same?
How to take out the overlap parts of curves
How can I randomly divide a list of surfaces in 3 separate lists?
OnCurve + SortAlongCurve
Calculate number of the point on the face
Generating Wooden floorboards + balustrades that intersect with a pattern
Trouble with Delaunay Mesh [Grasshopper]
Successive Increase in distance between Objects
Cookie pot
What does the "U V W" in surface morph mean? And how can I set them?
Creating Triangle surfaces from 2 curves
Shooting lines at a geometry and finding the points
Duplicated Tree Unflatten per grafted branch
