Hey there, just wondering if anyone is aware of a tool for sending and receiving MIDI info for Grasshopper in Rhino 6? Cicada used to work really well in Rhino 5, but doesn’t seem to work in Rhino 6. I posted on the Food 4 Rhino page for Cicada to see if it can be updated anytime soon, but I think the developer for this plugin has stopped supporting it
that would be awesome!
I once botched something together by using a CPython script using the midio library to receive the MIDI signals and passing them on the Ghowl in Grasshopper via UDP. Not very convenient as you have to start the external script manually but it worked. I can try to find the code again, if you are interested.
See you
Flo
Hey Flo! Thanks for the reply! That would be ace if you have the time to dig it out again. I’m actually fiddling with UDP on a few other projects + finding that GHowl isn’t great at receiving numbers over UDP - not sure if you had the same issue before? Seems all of my issues are pointing back to this post! Haha,
Have you tried this one?
https://www.food4rhino.com/app/cicada-midi-controller
