I have the following problem when trying to create a mesh from a closed Brep, created using a 360° Revolution of a closed polyline:
When I bake the closed brep from Grashopper to Rhino and insepct it, all seems fine (see following two screenshots)…
If I now use the “Mesh Brep” Function in Grasshopper and bake the results, the Mesh looks strange / half transparant even tho the details say it is a closed valid mesh:
I tried unifying the normals and welding the mesh, but with no vsible result.
If I do the meshing in Rhino and not Grasshopper, everything works as expected:
Do you have any idea, what could cause the meshing in Grasshopper to create the shown results? In other situations the meshing in grashopper works fine, it only appears with my brep created by the revolution of a closed polyline…
