Hello
Why these meshes have different welding result?
weld problem.gh (16.6 KB)
It seems to be a tolerance problem. After trying to invert the order of faces/vertices.both so your two examples match perfectly, I ended up rounding the coordinates of the vertices to 0.01, and the weld component worked.
You can use Align Vertices
component to avoid rebuilding the mesh.
These components surely doesn’t use a tolerance, they surely use something like a hashset. So if points are exactly the same they are glued.
Here the example
First example 4 points differents
Second example 5 points differents
private void RunScript(List<Point3d> pts, ref object A)
HashSet<Point3d> h = new HashSet<Point3d>();
foreach (Point3d pt in pts)
h.Add(pt);
A = h.ToList();
I already tried Align Vertices but didn’t work, and there no input for tolerance as @laurent_delrieu mentioned
Can you show your result?
In Blender we can collapse duplicated vertices but i don’t find an option like that in Grasshopper.
There are some component that uses tolerance.There is one from Petras in Ngon I think or Cockroach.
Thank you @magicteddy
Align vertices solve the problem
