Greetings, I have a list of mesh vertices IDs and I would like to unweld mesh at those vertices.
https://developer.rhino3d.com/api/RhinoCommon/html/M_Rhino_Geometry_Mesh_UnweldVertices.htm
Seems like a perfect solution, except I can’t get it to work.
My current mesh is completely welded with no creases, if I unweld it it doesn’t change behavior.
I have read the tips for the method and I did TopologyVertices.TopologyVertexIndex() but the provided list has the wrong indexing no matter how I approach it.
I couldn’t get .UnweldVertices() to work properly, neither in python nor C#
To solve the problem I got topology edges indices for vertices (thankfully they were somewhat ordered) and .UnweldEdge() worked like a charm.
Picking vertices inside rhino on a mesh and using UnweldVertex works flawlessly as well (but is not a solution as I need this automated in gh).
Here’s an example for unwelding mesh edges:
import Rhino.Geometry as rg
topo_edge_indices = []
for i in range(M.TopologyEdges.Count):
if M.TopologyEdges.IsEdgeUnwelded(i):
continue
line = M.TopologyEdges.EdgeLine(i)
pt = line.PointAt(0.5)
rc, _ = C.ClosestPoint(pt, t)
if rc:
topo_edge_indices.append(i)
M.UnweldEdge(topo_edge_indices, False)
sub_meshes = list(M.ExplodeAtUnweldedEdges()) # optional
a = sub_meshes
Keep in mind that many Grasshopper components actually don’t seem to respect unwelded edges somehow. A prominent example would be Catmull-Clark Subdivision from Weaverbird.
unweld_edges.gh (7.3 KB)
