Mesh typology based stripe pattern making
Hi, I am very new to grasshopper. But I notice this paper about inverse design of surface-base inflatables. I am curious wheather if its possible to do it with grasshopper? as making Keenan Crane’s stripe patterns (Keenan Crane - Stripe Patterns on Surfaces) base on the mesh typology?
Depending on your goals you might have some success using the Ivy plugin. To my knowledge you will have to get into custom scripting to go much further than that (but it has been a while since I’ve done this stuff!)
If you’re willing to dive into custom scripting (and pick up some math along the way), it is very rewarding to play around with those mesh traversal/differential geometry algorithms.
Typology? Do you mean topology?
Here’s one of many posts you can find by searching for ‘stripper’
