I would like to ask about this old script of yours about mesh curve offset:
I found its use by computing medial axis similar to this post:
Do you think there is a faster method to compute curve offset or somehow optimize your script?
Currently it takes a few seconds to compute:) Any ideas would be very helpful.
Also maybe you C# version instead of VB?
Hey Petras
first it is not really offset but geodesic distance calculation. The values are geodesic distances from one or many points.
It is based on these papers
Yes the script could be faster but I never implemented it. As it works with exact geodesic distances it works with “windows” and windows could be merged if an error is accepted. So it becomes faster. You could also use heat method developped by Keenan Crane https://www.cs.cmu.edu/~kmcrane/Projects/HeatMethod/
I didn’t implement it.
Offset of 3d volume could also be used to calculate sort of skeletton, see this :
Here my script in CS. But I didn’t get too much into it as I have not much use of it at the moment. MedialAxis_petras_CS.gh (46.8 KB)
Have a look at the Skeletonization component in https://www.food4rhino.com/app/capybara
You can also find a family of geodesics (and their conjugates) to remap your mesh into a quad mesh.
All the algos come from libigl and CGAL, you can find more info by right-click->help on some of its components. The library is a C# wrapper to C++ functions, therefore it should be pretty fast.
You are looking at how to compute the Distance Transform, one algo that I like is called Jump Flooding Algorithm or JFA, the paper is online and it is easy to implement
I have a question about Mesh Skeleton component each time that I connect my mesh to the component it generate different centerline and some times it is bind of mesh boundary ?
