Mesh Segmentation
I need to segment a mesh for laser processing. In areas with high Gaussian curvature, I plan to divide the mesh into small regions, while in areas with low Gaussian curvature, I want to create larger blocks to reduce machine movement and improve laser processing efficiency. Currently, I’m using the k-means method to segment the mesh, which can segment it into blocks of specified dimensions, but I don’t know how to merge the regions with low Gaussian curvature. Could someone help me? Additionally, I have both surface and mesh data available, which can both be used @dale
MeshSegmentation.3dm (964.3 KB)
this is what I want
this is what I get
this is my code
public class MeshSegmentation
    /// <summary>
    /// </summary>
    public static void SegmentMeshBySize(
        Mesh inputMesh,
        double maxSize,
        out List<Mesh> segmentedMeshes,
        out List<Color> colors)
        segmentedMeshes = new List<Mesh>();
        colors = new List<Color>();
        var faceIndices = new List<int>();
        for (int i = 0; i < inputMesh.Faces.Count; i++)
            faceIndices.Add(i);
        var results = RecursiveSegment(faceIndices, inputMesh, maxSize, 2);
        segmentedMeshes.AddRange(results);
        var rnd = new Random();
        foreach (var m in segmentedMeshes)
            Color color = Color.FromArgb(255, rnd.Next(256), rnd.Next(256), rnd.Next(256));
            colors.Add(color);
    /// <summary>
    /// </summary>
    private static List<Mesh> RecursiveSegment(
        List<int> faceIndices,
        Mesh sourceMesh,
        double maxSize,
        int clusterCount)
        var outputMeshes = new List<Mesh>();
        if (faceIndices.Count == 0)
            return outputMeshes;
        var faceCenters = new List<Point3d>();
        foreach (int i in faceIndices)
            faceCenters.Add(GetFaceCenter(sourceMesh, sourceMesh.Faces[i]));
        int[] labels = KMeansCluster(faceCenters, clusterCount);
        var clusters = new Dictionary<int, List<int>>();
        for (int i = 0; i < labels.Length; i++)
            int label = labels[i];
            if (!clusters.ContainsKey(label))
                clusters[label] = new List<int>();
            clusters[label].Add(faceIndices[i]);
        foreach (var kvp in clusters)
            var indices = kvp.Value;
            Mesh m = ExtractMeshFromFaces(sourceMesh, indices);
            if (m == null || !m.IsValid)
                continue;
            var bbox = m.GetBoundingBox(true);
            double dx = bbox.Max.X - bbox.Min.X;
            double dy = bbox.Max.Y - bbox.Min.Y;
            double dz = bbox.Max.Z - bbox.Min.Z;
            if (dx > maxSize || dy > maxSize || dz > maxSize)
                var subMeshes = RecursiveSegment(indices, sourceMesh, maxSize, 2);
                outputMeshes.AddRange(subMeshes);
            else
                outputMeshes.Add(m);
    /// <summary>
    /// </summary>
    private static Mesh ExtractMeshFromFaces(Mesh source, List<int> faceIndices)
        Mesh result = new Mesh();
        var vertMap = new Dictionary<int, int>();
            var face = source.Faces[i];
            int[] indices = face.IsQuad
                ? new[] { face.A, face.B, face.C, face.D }
                : new[] { face.A, face.B, face.C };
            foreach (int vi in indices)
                if (!vertMap.ContainsKey(vi))
                    int newIndex = result.Vertices.Count;
                    result.Vertices.Add(source.Vertices[vi]);
                    vertMap[vi] = newIndex;
            if (face.IsQuad)
                result.Faces.AddFace(vertMap[face.A], vertMap[face.B], vertMap[face.C], vertMap[face.D]);
            else
                result.Faces.AddFace(vertMap[face.A], vertMap[face.B], vertMap[face.C]);
        result.Normals.ComputeNormals();
        result.Compact();
        return result;
    /// <summary>
    /// </summary>
    private static Point3d GetFaceCenter(Mesh mesh, MeshFace face)
        var a = mesh.Vertices[face.A];
        var b = mesh.Vertices[face.B];
        var c = mesh.Vertices[face.C];
        if (face.IsQuad)
            var d = mesh.Vertices[face.D];
            return new Point3d((a.X + b.X + c.X + d.X) / 4.0,
                               (a.Y + b.Y + c.Y + d.Y) / 4.0,
                               (a.Z + b.Z + c.Z + d.Z) / 4.0);
        else
            return new Point3d((a.X + b.X + c.X) / 3.0,
                               (a.Y + b.Y + c.Y) / 3.0,
                               (a.Z + b.Z + c.Z) / 3.0);
    /// <summary>
    /// </summary>
    private static int[] KMeansCluster(List<Point3d> points, int k, int maxIterations = 100)
        var rand = new Random();
        int n = points.Count;
        var centroids = new List<Point3d>();
        var labels = new int[n];
        for (int i = 0; i < k; i++)
            centroids.Add(points[rand.Next(n)]);
        for (int iter = 0; iter < maxIterations; iter++)
            for (int i = 0; i < n; i++)
                double minDist = double.MaxValue;
                int best = 0;
                for (int j = 0; j < k; j++)
                    double dist = points[i].DistanceTo(centroids[j]);
                    if (dist < minDist)
                        minDist = dist;
                        best = j;
                labels[i] = best;
            var newCentroids = new Point3d[k];
            var counts = new int[k];
                newCentroids[j] = new Point3d(0, 0, 0);
                newCentroids[label] += points[i];
                counts[label]++;
                if (counts[j] > 0)
                    newCentroids[j] = newCentroids[j] / counts[j];
            centroids = new List<Point3d>(newCentroids);
        return labels;
On your initial description you talk about curvature, but then in your code you are using meshes and no method to get the curvature…
Can you explain better what are you trying to do and how your code was supposed to work?
Sorry, I didn’t explain it clearly. Currently, my code uses clustering to partition the mesh, but the result doesn’t produce larger blocks vertically as shown in the reference image. So I’m starting to consider whether it’s possible to merge some color blocks by judging the curvature.
