Mesh fix for non manifold mesh
Hello again.
I am going to process quadremesh on these mesh, but I cannot proceed with lots of non manifold mesh in it. I know the way is to delete all of them and append any holes on it, but I need a quicker way. Does anyone know? thanks
240812_non manifold mesh fix.3dm (1.7 MB)
non manifold.3dm (4.5 MB)
How did you create the mesh?
Its from a Maya designer from client’s side
The mesh seems to miss some faces too. The border isn’t continuous.
Can you Shrinkwrap your way to freedom?
Shrink wrap does not work on this shape. Isn’t it?
Yes, I am asked to convert it to nurbs face…
Why don’t you aslk the Maya designer to provide a better file? The geometry you shared above is garbage. If that is not possible, just rebuild the border and sweep2 some rebuilt profiles…
Just asked a more complete 3D from them. Uploaded
You can see from the first post for more complete object, lots of non manifold mesh there. Thanks
Weird object. But you can Shrinkwrap it and then Quad Remesh with symmetry…
non manifold shrinkwrap quadremesh nurbs.3dm (7.2 MB)
Thanks, looks like it is 2 objects there but I found it “attached” altogether. What is the setting of shrinkwrap to this result? thanks.
The lower the better. Start with 2 and then lower it to maybe 1 and then 0.5 and 0.2
