What is the difference between the _MergeCoplanarFace command and the
_MergeFaces command in rhino?
_MergeFaces let’s you delete a mesh edge between two faces which do not have to be planar.
_MergeCoplanarFace requires you to select two faces and not only works on meshes / SubD but also Polysurfaces
Thinks.
