I’m attempting to measure the length between two points by creating a line through the points. I’m using the Polyline: Through points feature to draw a line. I’d like to get the measurements between the two points by analyzing the length of the line.
Any idea on an easy way to do that?
Thanks everyone!
Everything you’ve said has been extremely helpful!
Hi James- you can save some steps by running the Distance command and snapping (point Osnap) to the two points. The distance is reported at the command line.
