Maximum amount of rhino layouts? Is there a limit?
Hello there,
I’ve recently been setting up multiple rhino layouts that include detailed views and attribute user text embedded in the block sheet template. At the moment I have 34 layouts but not sure if there is a maximum amount of layouts you can add to a file. I need to eventually create 300 layouts, can it handle 300? Trying to avoid having multiple files and would ideally to have everything saved in one file. The model at the moment is 318,500 KB but will be increasing in size as I add more blocks into the model space. Many thanks
Hi Stephanie -
There is no hard-coded cap on the number of layouts that I’m aware about.
In this thread, a user had 1356 layouts:
There’s a plug-in (for Rhino 5) to manage large amounts of layouts:
https://www.food4rhino.com/app/layout-manager
