Copy - paste
Pourquoi est-il si long de copier (ctrl + c) un objet sur un gros fichier même si l’objet est tout petit?
La commande Copytoclipboard reste gelée pendant de longues minutes à chaque fois…
Merci
mac or pc?
systeminfo?
are you doing this in shaded or rendered mode?
It could have to do with the rendermesh being recalculated after you paste the parts into the large file…once you paste, look at the command line, does it say anything about meshing?
Another possibility might be that you have some large textures in the original file and they are being copied/pasted with your objects - this is bug which I’m not sure has been fixed yet…
Bonjour
C’est un PC
Je le fait en mode ombré.
Le probleme survient au moment ou je copie. Quand je colle pas de soucis…
Systeminfo:
Rhino 6 SR29 2020-8-25 (Rhino 6, 6.29.20238.11501, Git hash:master @ 06b936ae4e8c289ecccfd6b5ee9bacccc60eded1)
License type: Commerciale, version 2020-08-25
License details: Cloud Zoo. In use by: Guillaume DUPAS (ARCHITECTIA)
Windows 10.0 SR0.0 or greater (Physical RAM: 32Gb)
Machine name: AA-PC05
Non-hybrid graphics.
Primary display and OpenGL: NVIDIA Quadro P4000 (NVidia) Memory: 8GB, Driver date: 6-21-2020 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 451.48
Secondary graphics devices.
  • NVIDIA Quadro P4000 (NVidia) Memory: 8GB, Driver date: 6-21-2020 (M-D-Y).*
OpenGL Settings
  • Safe mode: Off*
  • Use accelerated hardware modes: On*
  • Redraw scene when viewports are exposed: On*
  • Anti-alias mode: 4x*
  • Mip Map Filtering: Linear*
  • Anisotropic Filtering Mode: Height*
  • Vendor Name: NVIDIA Corporation*
  • Render version: 4.6*
  • Shading Language: 4.60 NVIDIA*
  • Driver Date: 6-21-2020*
  • Driver Version: 27.21.14.5148*
  • Maximum Texture size: 32768 x 32768*
  • Z-Buffer depth: 24 bits*
  • Maximum Viewport size: 32768 x 32768*
  • Total Video Memory: 8 GB*
Rhino plugins
  • C:\Program Files\Rhino 6\Plug-ins\Commands.rhp “Commands” 6.29.20238.11501*
  • C:\Program Files\Rhino 6\Plug-ins\rdk.rhp “Renderer Development Kit” *
  • C:\Program Files\Rhino 6\Plug-ins\AnimationTools.rhp “AnimationTools” *
  • C:\Program Files\Rhino 6\Plug-ins\Tibidabo\Tibidabo.rhp “Tibidabo” *
  • C:\Program Files\Rhino 6\Plug-ins\RhinoRender.rhp “Rhino Render” *
  • C:\Program Files\Rhino 6\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 6.29.20238.11501*
  • C:\Program Files\Rhino 6\Plug-ins\rdk_ui.rhp “Renderer Development Kit UI” *
  • C:\Program Files\Rhino 6\Plug-ins\import_ACAD.rhp “AutoCAD file import: import_ACAD” *
  • C:\Program Files\Rhino 6\Plug-ins\NamedSnapshots.rhp “Snapshots” *
  • C:\Program Files\Rhino 6\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 6.29.20238.11501*
  • C:\Program Files\Rhino 6\Plug-ins\RhinoCycles.rhp “RhinoCycles” 6.29.20238.11501*
  • C:\Program Files\Rhino 6\Plug-ins\Tibidabo\VisualARQ.rhp “VisualARQ” *
  • C:\Program Files\Rhino 6\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 6.29.20238.11501*
  • C:\Program Files\Rhino 6\Plug-ins\Tibidabo\Lands.rhp “Lands Design” *
  • C:\Program Files\Rhino 6\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 6.29.20238.11501*
  • C:\Program Files\Rhino 6\Plug-ins\3dxrhino.rhp “3Dconnexion 3D Mouse” *
  • C:\Users\Guillaume\AppData\Roaming\McNeel\Rhinoceros\6.0\Plug-ins\Twinmotion Direct Link 2020 (e24ee14a-9514-47da-8fe6-f6e61b20160e)\Twinmotion Direct Link 2020.rhp “Twinmotion Direct Link 2020” 1.0.0.0*
  • C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\V6\VRayForRhino.rhp “V-Ray for Rhino” *
  • C:\Program Files\Rhino 6\Plug-ins\Displacement.rhp “Displacement”*
oui, c’est vrai que j’ai quelques textures un peu grandes par contre elles sont attribuées à un matériaux VRAY associé à un calques et pas aux objets…
that is quite likely the culprit.
